Fault codes: 0335 and 0607
So I had a tappet noise issue, turns out there was only 1.6L of VERY black oil in my Corsa C. I changed it, put 3.6L of 10w 40 semi in and the tapping has COMPLETELY gone.
After changing oil (+Filter), air filter and spark plugs the car no longer has a lack power and it's not powerless in all gears. Instead it goes straight into limp mode as soon as it's turned on.
Fault codes from pedal test 0607 and 0335.
Crankshaft position sensor is 0335, but not sure on 0607 as it's not in the list fault codes. I've checked 4 times that it's 0607 and it 100% is.
I've not been able to start the car consitently too, which might be because of 0335. My question is, how can I find a GENUINE crankshaft position sensor, there's all different ones. I THINK Bosch are the brank for the CPS sensor, however I can't find one on ebay and I don't want a non-genuine after-market one as Vauxhall don't like them very much apparently!
EDIT - Before the spark plug change the car started up INSTANTLY, and there was no 0335 before. The 0335 has only occurred after this mini-service, now 0335 is a fault code, which could be why it's not starting properly unless I pump the pedal slightly. Also before the mini-service, I had no limp mode but the driving was very similar to the symptoms of a broken MAF, and there was a fault code of 0110 with is IAT sensor. Should I reset the ecu over-night and then check code again or?
Regards,
Regards,
