1 - 20 of 26 Posts
Hi
could anyone help, i got a 1.4 sport and within the first 10 mins it starts to run really hot and the fan comes on, the engine managment light comes on and everytime i slow down it starts to rev at about 2000 rpm and doesnt go down till i tap the pedal. The engine has done 89,000 miles and its a 1996 if it helps.
If anyone has ideas id appreciate as i cant even drive it at the min. Cheers.
how old is the air filter?
Its standard with the car, not been changed.
Also at 60,000 ish miles it had an engine change.
Apparently the engine put back in was the same mileage and it was from silverlake.
so is the pannel filter old?
if it is run the engine untill hot and it starts to do what its doing. turn it off
remove filter and start it again. make shore nothing falls into air intake. and
see if that helps, just a case of buying a new filter.
if not then could be a vacuum leak at fuel injection unit low cylinder
compressions.
Discussion Starter #5
ye someone sed it could be a vaccum leak but would that be a reason for it to get so hot so quickly.
the water tank has also got rust in so that mite need a flushing out, would that help?
Would replacing the filter help with the high idling problem?
yes it should help, and it could need a flush, does the engine lack power?
Discussion Starter #7
not dramatically, its hard to tell really.
if that dusnt work is there any chance if it being a sign the head gasket is on its way out or anything like that?, as these engines do get hot.
is there any mayonnaise type stuff under oil cap?
and has it always been like this since the engine change?
Discussion Starter #9
no theres nothin on the cap or the dipstick but are there any other ways of telling?
and i dont know if its been like this since the change but i dont think its has cause its been a run around car for the guy i bought it off.
could it be that its been run with no water in the tank or something?
it doesnt sound like it, unless you have to top up water regular basis.
but it could be that ignition timing is incorrect, if taking the filter out hasn't
worked,
this your engine?
does it misfire?
Discussion Starter #15
nope, it runs ok, it just gets hot quickly and idles at 2000 rpm when i slow down or stop till i tap the pedal.
id change the pannel and flush the rad,
have you done a paperclip test?
its when you short the diagnostic socket to flash a code of recognised
problems or faulty sensors to the EMU (Engine Management Unit)
clicky link
Discussion Starter #19
cheers mate thats really helpful.
ill try replacing the filter and flush it out and if that dusnt work ill do that test.
let me now how you get on. :thumbs_up:
1 - 20 of 26 Posts
