Hi,my son has a 2000 corsa c 1.2sxi, the airbag light is on (mot fail) the garage tried re-setting it with there system but it could not link with the airbag, only engine management, i then had a diagnostics specialist come out to the car but he also could not connect either of his two systems, after checking fuses etc he says he does not think there is a live feed going to the control unit( behind center column) is there an additional fuse to number 32 or a relay that might cause this?
Also if anybody knows what colour the feed wire is at the connector block that would be really helpfull.
Thanks, Mark
Thanks, Mark
