Hi I have a 1998 Vauxhall Corsa B 1.4 we recently changed the head gasket and since then the car is making a loud rattling noise when I reach 3000 revs. It sounds like it is coming from the timing or fan belt area.
My fan belt has seen better days, in other words its got cracks all over and will probably snap soon, but its not squealing.
Any ideas?
Welcome to the Forum.
If the noise WASN'T there before you changed the head gasket, I would suggest that you double check that the valve timing is set correctly.
Are there any other symptoms (performance, for example)?
I would recommend that you change that auxiliary drive belt ASAP before it lets you down.
Regards
