*This is for the whole car only*
For Sale Full 20xe conversion, Engine, Gearbox, ECU, Loom, Driveshafts & 2ltr Brakes + comes with a free corsa shell on steelies 95k, stripped out got front two seats only and front dashboard/centre console, no door panels, rear seats!
The engine is a early dizzy type from a astra gte, mileage unknown! the engine was rebuilt and port and polished by the previous owner last year and covered 500 miles then was off roaded stored in a garage, then i brought it for a mate 2 months ago and is now stuck on my drive!
and hasnt moved so been sat awhile .
The engine had a running problem when i brought which was the revs going up and down on idle and then dieing so replaced tps and afm still no joy, then started stripping apart found the top hat had a massive crack which must have been causing unmeasured airflow! now this is how it stands brought a power cap & couldn't be assed to finish with knocking bulkhead back etc so it just got left.
other things to note, its got full silicone hose upgrade, front mounted oil cooler, chipped ecu, uprated fuel pressure regulator and the previous owner said it had uprated cams no proof and haven't checked!
Will be adding more pictures of how it stands now at weekend atm its being used as storage!
alm:
£450 ono + will need to be towed away
I Live in Northampton NN2
