1 - 10 of 10 Posts
Oh yeah didnt read it properly :rolleyes: I think they will be fine, you wont really need V6 unless your a track day whore :laugh:
here you go dearing, some info to help you decide which will suit you better
Grooved discs.
1. grooves clean the pad surface and increase the brake faces (the leading edges of the grooves) so in theory the more grooves the more faces.
2. grooved discs can be used with any pad material as the disc is more durable than a drilled version.
3. discs life is longer than a drilled equivalent.
Disadvantages.
Disc is heavier than a drilled equivalent.
Drilled discs.
1. Lighter weight than a grooved equivalent
2. Good brake bite due to:
A forcing pad material into the holes
B increased braking surface (many leading edges in theory)
3. allowing gases formed during the braking cycle to escape from the disc braking face.
Disadvantages.
Discs can be prone to cracking unless care taken when bedding in
The use of hard race pads(high friction level) can cause cracking giving the disc a limited life.
ive ordered the grooved as they seem the better option!
black diamond oh i cant wait! look **** hot.
cheeky ordered some brembo brake caliper stickers.
no one will no any different ;)
1 - 10 of 10 Posts
