1 - 1 of 1 Posts
I have 2014 1.3cdti engine prefix is A13DTR with six speed gear box. It has had a con rod snap on number three cylinder and has punched holes through the block, two through the iron part and one through the bottom part that the sump bolts on to. Top end is good, head and all fittings. Number three piston had split in two and was stuck in the bore, but did not damage the valves or the head, it has about an inch of con rod still in side it with the little end. The rest of the con rod was in three bits in the wrecked sump. I need to know if the previous model Corsa, (ie) pre 2011 with the J engine prefix will fit, is it the same block, ? and will my old flywheel and clutch, and six speed box fit any other model. The car seems to good to scrap. Please help.
1 - 1 of 1 Posts
