Hey all, I've just been visiting another Corsa forum & they really hate 6x9 speakers. I have 6x9 Pioneers in my parcel shelf & I think they sound fine!
As far as I know, components are seperate speakers, you have the mid range woofer and the tweeter seperate, so you can mount them wherever you like, allows more flexibility with creating the soundstage. Coaxials are full range units built in together, meaning its effectively 2 (or more) speakers mounted together. From what I can tell, components sound much better than their coaxial equivilent, even if you mount them in the stock locations. With components it's like each speaker is doing only 1 thing, but its doing what it does best rather than one speaker trying to do a bit of everything. Also, if you buy a set of components, you won't need to buy seperate tweeters as they are part of the component set alreadyWhats the difference between components and coaxials? Tweeters are a good buy aswell mate.
yeah your right mate, components have seperate tweaters and a mid range driver, whereas coaxials have the tweater on top of the speaker.As far as I know, components are seperate speakers, you have the mid range woofer and the tweeter seperate, so you can mount them wherever you like, allows more flexibility with creating the soundstage. Coaxials are full range units built in together, meaning its effectively 2 (or more) speakers mounted together. From what I can tell, components sound much better than their coaxial equivilent, even if you mount them in the stock locations. With components it's like each speaker is doing only 1 thing, but its doing what it does best rather than one speaker trying to do a bit of everything. Also, if you buy a set of components, you won't need to buy seperate tweeters as they are part of the component set already![]()
Personally i think you should spend around £100 on a good set of comps, take look at infinity, alpine and rainbow's range they have some decent speakers for that price.Oh sweet, im looking to get a set and then wire them up to my amp that kandykorsa is sending me. How much should i spend on a set about?
