Need a tid bit of help..
I moved my car this morning and then tried to start it up 2 minutes later and nothing happens.
I turn the ignition to start it up and nothing happens it doesn't turn over or anything. No noise no sound. I'm not great with mechanics but I'm not sure whether it's the starter motor, the ignition switch or a short in the wiring somewhere..
Is there anybody out there that can help me resolve this situation?
Thanks.
I've now completed the following checks
I've removed and reinserted the relays
I've checked all the fuses
I'm doing the paper clip test atm (Just waiting for the ECU to reset)
I've checked the ignition barrel & switch
Still to be done
- Check the starter motor
Any other suggestions as to what to do/check are more than welcome
Thanks.
Thanks.
Still to be done
Thanks.
