1 - 1 of 1 Posts
  • If your fallopian tubes are blocked then with the aid of assisted reproductive IVF technology you can unlock your tubes and improve the chance of getting pregnancy.
  • Premature ovarian problem can be removed with the effect of IVF. If your ovary cannot produce eggs or produce poor quality of eggs then IVF helps in improving the quality of eggs.
  • With IVF you can increase your sperms rate or you can also prevent your sperm blockage problem.
  • If the problem of infertility is unknown which is called unexplained infertility then with IVF you can improve your fertility level and get pregnant naturally.
1 - 1 of 1 Posts
