Hello,
I have a 1ltr 04 Corsa C, not the daily driver, i have a fiesta mk5 zetec s for that
however, it does have the leak on the brake servo that they all have, so is currently under a tarpaulin. A few months ago the car wouldnt start, it would just turn over. Brought an opcom and it wouldn't let me get into the ECU ATALL. Trailered the car to a garage and they used Tech2 etc and couldnt get in. Eventually got in and it was an immobiliser fault, the key wasnt being recognized. (only came with one key so couldnt even try the other one) so i thaught it was dead and left it with the battery out for a good few months. Now it starts first time every time!!
The problem now, is that the airbag light is on at about 1/2 brightness when the ignition is OFF, as soon as you turn the key so all the dash lights come on, the airbag comes on (to full brightness) and then goes fully off with all the other lights.. start the car and the light stays out.
Plug the opcom in and there a no error codes what so ever. The airbag and everything are clear. However.. theres one section the opcom just refuses to load, the "Instruments" Section, just stays white, the loading character doesnt even spin : - "| / - \ |" etc.
Anyone know why the light is on dimmly when the ignition is off? It looks like a bad earth or something but im not sure where..
Done a bit of research and really cant find anything like it.. only the odd few but tried most of the things!
alm:
any help would be appreciated , thanks
Luke
Luke
