In my car I have 2 amps, a 2 channel amp running my sub, and a 4 channel amp running my 6X9's and hopefully soon my comps. Was driving home the other night when the head unit suddenly turned off. I had recently been cutting the ISO connector up to try and connect the door comps to the amp but failed so I re-connected the wires temporarily, I left the power cables alone so I don't know entirely how the head unit lost power like it did. Anyway I got a new ISO connector yesterday, switched the red and yellow wires around and the head unit is now working as it should, but for some reason no power is getting to the amps. I've checked all the fuses and they appear to be ok, the wiring hasn't changed from when they were working but I checked all the wires and they are all connected to where they should be, but nothing's working. I've connected the remote wire on the ISO connector to the amps as it was before, I'm thinking theres a problem there somewhere but like I said it IS connected so I can't work out what is wrong. Any ideas on other things to check, or what might be wrong? It's doing my nut in because as far as I can see it SHOULD work and it DID work, and I'm really missing my sub
lol
