1 - 14 of 14 Posts
Just a quick quiry really... I have these lights:
They're great but i was wondering about the wiring.
I wired the sidelight wires to the LED ring and the headlights and full beam seem to be working fine with the supplied bulbs i got with the lights but there is a couple of things i still havent really considered.
1. What did you do with the wires for the light height adjustments/motor
2. What goes in here or what can i put in here:
How do i wire an extra light up though because the wires are connected to the rings now.
there's no where for the sidelight bulb to plug into though the hole on the actual headlights is just loose and no plug.
does anyone know how to wire in the LED ring, I have bear ended wires. Im supposed to wire them to my sidelights, but not sure how to do it. A guide reads "The most common and recommend place to connect the Halo wires to are on your vehicle's PARKING light wiring harness." But how exactly?
I found this but it didnt help THAT much Click here
I assume all Corsas have the same PARKING light?
If so they only work with the ignition off and the indicator in the up/down position and then they only light one side!
The only way I could think of wiring them is through a seperate switch/fuse, that way you could switch them on/off seperatly.
EDIT: Having looked at the picture and then at my Corsa, I have one indicator, one sidelight, one dipped headlight and one for main beam, is this the same as your Corsa?
I had a mad idea to connect a switch onto the standard light switch that would switch between sidelights and the 'halo' lights, but that might be a bit more difficult.
Mine are exactly the same as LAD VXL's in pics above...
I just need to connect the halo rings to the same plug/socket/wire as the sidelights/parking lights use, i've plugged the bare wires for the rings into the sidelight socket itself to try them and they work but then obviously i cant then plug my parking/sidelights into the same one....
I get it!
You need to cut the sidelight wire and solder the 'halo' wire into it, remeber to make sure it's waterproof when you've finished though!
I remember a clip years ago that when shut it would attach a second wire to one that already exists, I think they're called scotchblocks, but they're a bit of a bodge!
1 - 14 of 14 Posts
