Ok so I refurbished my wheels and painted them white.
here's a quick write up/guide/diary.
So first, remove the wheels from the car.
Next, identify all the damage
Didnt get any picutres of the next step, but give them a VERY good clean.
Then, got some alluminium alloy wheel filler. This is like Isopon P38 but contains metal shavings. and is tougher.
Now put the filler on and sand down until completely smooth
Now, choose your poison. I decided to go with Halfords Appliance White Gloss.
Heat up the paint in a bucket of hot water - not boiling.
Whilst the paint is warming up, sand away any toughened crap stuck to the inside of the wheels.
Next, apply several thing layers of primer, giving 20-30 minutes between each coat.
Here, I done the inside of the wheel, as well as the outside.
When its dry, sand down with a very fine wet and dry paper.
Then, apply the paint which should have been warmed up in the water as well
Repeat the process by adding more coats when dry, and then fine sanding, then add the laquer.
You should end up with something resembling semi-decent alloys
I photoshopped the wheel to give it the red lip, but not decided on it yet
