Hi so i bought my corsa and got a bodykit thrown in free of charge :)
well im only going to fit the front bumper i think. its in a pretty bad state and its been sprayed very bad so im going to spend my weekend off fixing this basically i just need a materials list because not too sure what to buy.
:lipsmoker:
wet and dry,,,,,,,,,,,a good sand to fix any rough edges ,,use heat on any cracks or breaks helps weld it together,,,,,,,,,2/3 coats of primer and 2/3 coats of paint te fit should look sweet
Thanks For Quick Reply do you think black mesh would suit the grills with silver vauxhall lettering on where the previous standard grill was. would look good.
:thumbs_up:
If your colour coding it and want a gloss finish dont forget 2/3 coats of lacquer after the paint, will need to give it good polish with a compound after that to get a smooth gloss finish :thumbs_up:
Id say you need:
-wet and dry,240,500,1200 might need something more corse depends how bad it is
-p38 filler is theres any scrapes etc
-if your spraying on plastic then make sure you use plastic primer
-paint
-lacquer
-cutting compound ( i use G7)
