1 - 6 of 6 Posts
In the brake fluid reservoir :p, lift the bonnet, on the same side as the washer bottle, there is a plastic cover attached to the scuttle panel, lift the plastic up and there's the reservoir, hope this helps :)
Thanks do I just put in any brake fluid from Halfords also how much do u out in? Is there like a dipstick or markers?
Think you need a Haynes manual duck, brake fluid only needs topping up if you've been working on the brakes
1 - 6 of 6 Posts
