1 - 8 of 8 Posts
Can you simply take off your front discs and replace them with astra GSI ones ? or is some kind of conversion kit required?
Cheers :D
right, 11mm socket to loosen the brake flexi from the caliper, take the flexi off the caliper, 7mm allen key to remove the caliper, then a 10mm allen key to remove the pad carrier, once these are off just, fit the gsi disc then the gsi pad carrier then bolt on the gsi caliper and refit the flexi to the caliper, mke sure you refit the wee wire springs to the outside of the calipers when your done and make sure your wheels are bigger then 13s lol
job done
what davie is tryin to say is you need the bigger calipers as well, and once you have those, there is your guide to fitting :p
glad to help buddy ( am sure davie is as wel ;) )
good stuff, slightly more acceptable noise level now lol ??
On the corsa u can take any bigger braking system from the 2.0ltrs like the astra f series and its a straight fit... all u need to remember is to bleed the braking system once done cause u removed the brake fluid lines when changing calipers
1 - 8 of 8 Posts
