1 - 14 of 14 Posts
Hi,
I have just changed my heater control bulbs in my corsa b and they still dont seem to be lighting up. Maybe its the fuse?
Do you know where this fuse is located and what amp it needs to be. I have just tried to install 12V Blue LED (T5 (286) Push fit dash board)
Any help?
Luke
when replacing the bulbs you may have broke the circuit for them, as the part they are mounted on is a bitch to get off the front of the centre consle and you might have damaged it
Discussion Starter #13
Finally got it working! Just did loads of combinations of swapping around and bingo! Must of swapped around about 3 times. Knowing my luck they wont work next time!!
1 - 14 of 14 Posts
