C20xe Block £150 (Block been cleaned down ready for painting, pistons also been cleaned & shining, complete with engine stand & piston ring compressor)
C20xe Fat Flywheel £20
C20xe Genuine Bosch Airflow Meter £30
C20xe Coscast Head Cylinder Inc Valves ECT £140
C20xe Top Cam Cover £20
C20xe Driveshafts To F20 Box, Corsa B Conversion £80 ( Believe Theses Are The 300bhp Shafts )
C20xe Camshafts With Pulleys £40
C20xe Alternator £25
C20xe Big Brake Conversion For Corsa B (Calipers Only) £30
C20xe Throttle Bodie £15
C20xe Bosch Distributor Cap, 5 x HT Leads & Extra Coil £50
C20xe Inlet Manifold, Fuel Rail, Cream Injectors, FPR £30
C20xe Starter Motor £25
C20xe ECU & LOOM £40 (Not Complete)
C20xe F20 Gearbox, £40
Will take £400 For The Lot
