Been wanting to do a conversion for a while but don't really have the time and I don't think my car's shell is up to scratch.
I've come across what appears to be a very good example of Corsa that's already had a C20XE conversion carried out. Just got a few questions to make sure there's nothing I've missed or anything that rings alarm bells to some of the more knowledgeable on here.
A bit about the car:
ENGINE:
It's a 1989 C20XE engine, distributor and rotor arm type.
Fairly sure the conversion was done by a garage, chassis strengthening was done.
Engine was rebuilt around 10,000 miles ago to standard spec (new pistons, bearings, cam belt etc.)
Ported and polished head and a new clutch with lightened and balanced flywheel.
Head gasket blew a few thousand miles ago, an uprated gasket was fitted when being fixed and it has driven fine since.
Fan works well so the car doesn't overheat, although apparently it's still using a standard 1.2 radiator.
The rocker cover gasket has been changed a few times but there's still a very small leak coming from the top left of it.
It's a weekend toy but 9 times out of 10 the bloke has his kids with him so it doesn't get thrashed around. As it can go a few weeks at a time between driving, on start up it can be a bit tappy, but after it's warmed up it quietens down. An additive has been added to the oil to help with this.
It idles fine at around 900rpm.
BODYWORK:
There are a couple of small rust bubbles at the top of both front wheel arches. The paint hasn't been pierced but there is obviously signs of a bit of rust developing.
The shell only has about 50,000 miles on it and it's never been welded and it's been undersealed.
It drives straight and has four new tyres that are all balanced up, the tracking was done so that it had a bit more toe out to improve the handling.
All advisories were dealt with for the latest MOT, including all gaitors and a couple of CV joints.
It has full service history including all receipts for engine work and a certificate for the installation of a Cat 1 alarm/immobiliser and the guy knows the two previous owners so knows it hasn't been treated badly.
There are other bits I won't bore you with but it has lots of other extras and goodies that indicate it's been well looked after.
Just wondering if there's anything there that sounds a bit odd or should be a cause for concern?
Thanks.
ENGINE:
BODYWORK:
Thanks.
