Hi there,
I wonder if any of you guys can help with a problem I've been experiencing with my Corsa for a little while. Here's my cars spec before I start:
My car is VERY sluggish when I set off in the morning. Granted, it is cold outside at the moment and it is a diesel so I'd expect it to take a little while, but I think there may be a problem
As soon as I turn the ignition, the car starts up without any problem, however it seems to sit there and shudder before I set off (the rev's are at about 9000 which I think is normal?). I always make sure the little ignition light goes out before starting up - so it's not that causing the issue.
Anyway, once I set off the car is extremely sluggish to the point where if I floor the accelerator in first gear it takes a good 5 seconds before it starts to gain some pace. There's also a loud 'knocking' sound coming from the engine when at low revs... it's difficult to describe, but sounds like metal on metal? Could this be the pistons (I've had to google the name of them ha... I'm not mechanically minded)? This noise seems to disappear once I've gained a bit of speed or when I'm in a higher gear, and the knocking speeds up the faster I go (I think).
The car seems to 'kick-in' to action once I get past halfway on the rev counter - maybe when the turbo kicks in? And then runs fine when in higher gears. After a 30min drive at 30mph, as soon as I stop the car and start off in first gear, the noise is back (but to a lesser extent and the performance is less sluggish).
Can anyone offer any advice before I take it to a garage? Are there any checks I can do? Is it bad news?
Thanks muchly
Craig
Corsa 1.3 ecoflex (2009) 3dr diesel.
Thanks muchly
Craig
