that worked for me when u told meI'm sure to cure the memory issue, switch the red and yellow wires on the ISO connector. Connect yellow to red and red to yellow. In regards to making it work with the ignition off, I'm not too sure, but I think it's something along the lines of connecting the permanent live to the ignition. Hopefully someone will come along and correct or back me on this lol.
Mine does the same, and has done ever since my friend installed an amp!Hi I have a sony cd player and im having problems with it not holding its memory. Also I want to set it up so that I can use it when the ignition is off. What wires do I need to change to make it work ?
Cheers
