Okay so before I start I'd like to mention I know absolutely nothing about cars/engines.
So the other night I went out and when I went to start my car again the battery was dead, after a few tries it started again. The next day it fully died so I purchased a new battery and it worked fine. But apparently I also had another issue.
The oil light was on, I checked the dipstick and it was relatively low (on the low marker) so I topped it up. I started my engine and the oil light is still on. I did a small journey in the car (5 miles) and when I stopped I could see smoke coming out of the engine. When I popped the hood it felt hotter than it usually would and their was a burning smell.
Basically the syntoms are burning smell. Smoke. And oil light are on even tho I have full oil. Car runs fine. No strange noises and the drive feels the same as always.
I've read around and I'm assuming that the issue is either the oil pump. Oil sender or oil filter.
If anybody could help me out and give me any advice I would really appreciate it.
Edit: I should probably mention that the car is a 1998 s reg corsa 1.2. 16v.
