1 - 15 of 15 Posts
Part One
Tech Support: "I need you to right-click on the Open Desktop."
Customer: "Ok."
Tech Support: "Did you get a pop-up menu?"
Customer: "No."
Tech Support: "Ok. Right click again. Do you see a pop-up menu?"
Customer: "No."
Tech Support: "Ok, sir. Can you tell me what you have done up until this point?"
Customer: "Sure, you told me to write 'click' and I wrote 'click'."
(At this point I had to put the caller on hold to tell the rest of the tech support staff what had happened. I couldn't, however, stop from giggling when I got back to the call.)
Tech Support: "Ok, did you type 'click' with the keyboard?"
Customer: "I've done something dumb, right?"
Customer: "I received the software update you sent, but I am still getting the same error message."
Tech Support: "Did you install the update?"
Customer: "No. Oh, am I supposed to install it to get it to work?"
Customer: "I'm having trouble installing Microsoft Word."
Tech Support: "Tell me what you've done."
Customer: "I typed 'A:SETUP'."
Tech Support: "Ma'am, remove the disk and tell me what it says."
Customer: "It says '[PC manufacturer] Restore and Recovery disk'."
Tech Support: "Insert the MS Word setup disk."
Customer: "What?"
Tech Support: "Did you buy MS word?"
Customer "No..."
Tech Support: "Ok, in the bottom left hand side of the screen, can you see the 'OK' button displayed?"
Customer: "Wow. How can you see my screen from there?"
Customer: "Uhh...I need help unpacking my new PC."
Tech Support: "What exactly is the problem?"
Customer: "I can't open the box."
Tech Support: "Well, I'd remove the tape holding the box closed and go from there."
Customer: "Uhhhh...ok, thanks...."
At our company we have asset numbers on the front of everything. They
give the location, name, and everything else just by scanning the computer's asset barcode or using the number beneath the bars.
Customer: "Hello. I can't get on the network."
Tech Support: "Ok. Just read me your asset number so we can open an outage."
Customer: "What is that?"
Tech Support: "That little barcode on the front of your computer."
Customer: "Ok. Big bar, little bar, big bar, big bar..."
Part Two
Got a call from a woman said that her laser printer was having problems: the bottom half of her printed sheets were coming out blurry. It seemed strange that the printer was smearing only the bottom half. I walked her through the basics, then went over and printed out a test sheet. It printed fine. I asked her to print a sheet, so she sent a job to the printer. As the paper started coming out, she yanked it out and showed it to me. I told her to wait until the paper came out on its own. Problem solved.
I had been doing Tech Support for Hewlett-Packard's DeskJet division for about a month when I had a customer call with a problem I just couldn't solve. She could not print yellow. All the other colors would print fine, which truly baffled me because the only true colors are cyan, magenta, and yellow. For instance, green is a combination of cyan and yellow, but green printed fine. Every color of the rainbow printed fine except for yellow. I had the customer change ink cartridges. I had the customer delete and reinstall the drivers. Nothing worked. I asked my coworkers for help; they offered no new ideas. After over two hours of troubleshooting, I was about to tell the customer to send the printer in to us for repair when she asked quietly, "Should I try printing on a piece of white paper instead of this yellow paper?"
A man attempting to set up his new printer called the printer's tech support number, complaining about the error message: "Can't find the printer." On the phone, the man said he even held the printer up in front of the screen, but the computer still couldn't find it.
And another user was all confused about why the cursor always moved in the opposite direction from the movement of the mouse. She also complained that the buttons were difficult to depress. She was very embarrassed when we asked her to rotate the mouse so the tail pointed away from her.
Customer: "Hello? I'm trying to dial in. I installed the software okay, and it dialed fine. I could hear that. Then I could hear the two computers connecting. But then the sound all stopped, so I picked up the phone to see if they were still connected, and I got the message, 'No carrier,' on my screen. What's wrong?"
An unfailingly polite lady called to ask for help with a Windows installation that had gone terribly wrong.
Customer: "I brought my Windows disks from work to install them on my home computer."
Training stresses that we are "not the Software Police," so I let the little act of piracy slide.
Tech Support: "Umm-hmm. What happened?"
Customer: "As I put each disk in it turns out they weren't initialized."
Tech Support: "Do you remember the message exactly, ma'am?"
Customer: (proudly) "I wrote it down. 'This is not a Macintosh disk. Would you like to initialize it?'"
Tech Support: "Er, what happened next?"
Customer: "After they were initialized, all the disks appeared to be blank. And now I brought them back to work, and I can't read them in the A: drive; the PC wants to format them. And this is our only set of Windows disks for the whole office. Did I do something wrong?"
This guy calls in to complain that he gets an "Access Denied" message every time he logs in. It turned out he was typing his username and password in capital letters. Tech Support: "Ok, let's try once more, but use lower case letters." Customer: "Uh, I only have capital letters on my keyboard."
Email from a friend: "CanYouFixTheSpaceBarOnMyKeyboard?"
A woman called the Canon help desk with a problem with her printer. The tech asked her if she was "running it under Windows." The woman responded, "No, my desk is next to the door. But that's a good point. The man sitting in the cubicle next to me is under a window, and his is working fine."
Part Three
Tech Support: "OK Bob, let's press the control and escape keys at the same time. That brings up a task list in the middle of the screen. Now type the letter 'P' to bring up the Program Manager."
Customer: "I don't have a 'P'."
Tech Support: "On your keyboard, Bob."
Customer: "What do you mean?"
Tech Support: "'P' on your keyboard, Bob."
Customer: "I'm not going to do that!"
Overheard in a computer shop:
Customer: "I'd like a mouse mat, please."
Salesperson: "Certainly sir, we've got a large variety."
Customer: "But will they be compatible with my computer?"
Customer: "So that'll get me connected to the Internet, right?"
Tech Support: "Yeah."
Customer: "And that's the latest version of the Internet, right?"
Tech Support: "Uhh...uh...uh...yeah."
Customer: "My computer crashed!"
Tech Support: "It crashed?"
Customer: "Yeah, it won't let me play my game."
Tech Support: "All right, hit Control-Alt-Delete to reboot."
Customer: "No, it didn't crash -- it crashed."
Tech Support: "Huh?"
Customer: "I crashed my game. That's what I said before. I crashed my spaceship and now it doesn't work."
Tech Support: "Click on 'File,' then 'New Game.'"
Customer: (pause) "Wow! How'd you learn how to do that?"
I apologize if there are any doubles/repeats in there :)
The 2nd coming
aaaaahahahaha so true though....
had a guy yesterday, took 5 mins to realise he wasnt even connected to the internet :| stupidity of some poeople!
AOL users, everything people say about them is true!
when working for a small i.t. support company the higher up people were on the phone to a company who complained that the printer wasnt working.. it just wasnt printing.
After a long phone conversation about it they decided to send me off to take a looksie, so i went up to london bridge on the train, got lost finding this place, finally found it went in they took me to the printer.. the Ethernet cable wasnt plugged in as it was a network printer, yet the higher ups didnt bother asking this on the phone..
what a wasted journey!
working for the it department in a school, the amount of people who type their username and password in caps, that is irritating! they sometimes also seem to forget that you need to turn the monitor on or you cant see anything, instead they just say its broken
At work today i had someone trying to connect to the office via vpn when there already in office and couldnt work out why i wasnt working lol
and i had another where they thought they had a virus because when they opened up explorer it went to google-lol i said its you default home page they said does a virus do that then-lol
The 2nd coming
haha classics!
Yep ive had to walk all the way down to the ground floor (3 flights of stairs) to hit num lock or caps lock for people! stupidity
haha classics!
lol at college the best one was putting on sticky keys, or high contrast mode. or switching mouse to left handed.. well confuses people.. they shouldnt have left their computers unlocked :p
The 2nd coming
haha we did the same when i was at college, we'd even trojan the computers so we could piss people about lol!
Haha, I get customer's at work saying they have problems logging in. They enter stupid things like today's date as their date of birth - so stupid.
1 - 15 of 15 Posts
