Hi Peeps really need to know which sensor to change the code is P0136 O2 Sensor Circuit (Bank 1 Sensor 2) but where do i find that sensor and is there any special tools required i have a Corsa C automatic.
awaiting your responses cheers in advance :confused:
Welcome to the Forum.
Before you go spending money on new sensor(s) which may/may not be required, I would suggest that you check the connections.
There are two Lambda sensors, one on the cat itself and the other on the exhaust pipe which runs between the cat and the first silencer.
No special tools required, but I would allow it to soak in penetrating fluid (Plus-Gas is a good one) before you attempt to remove it.
I would recommend only genuine GM (Vauxhall) sensors, as some of the after-market ones leave a lot to be desired.
Regards
