Hi guys I’d be really appreciative of some help if you can. I have a Vauxhall combo 1.3cdti van I went to start it the other day and it wouldn’t start. A friend connected it to a fault diagnosis reader and it said that the high pressure fuel pump was faulty, I changed this for another one but it won’t start still. The pump at the back is pumping fuel to the filter, the filter is getting fuel to the high pressure pump but when I loosened one of the injector nuts there was no fuel getting to the injectors. Could someone please advise me how to bleed the system. Thank you
