First off, my van is well looked after. I service it regularly and repair anything as soon as I can. The engine is the Isuzu 1.7 D n/a
Problem 1: It has always slowly lost water from the cooling system. Neither the oil or coolant are contaminated with each other. The water level in the bottle just slowly goes down all the time. Over the last few years I have replaced with new: radiator, water pump, thermostat, header tank cap. It doesn't leak out of the engine or pipe work, it just slowly disappears! I gather that the head gaskets on these engines are bulletproof. The engine doesn't smoke ever, or overheat.
Problem 2: the rocker cover leaks oil. I replaced the rocker cover gasket last year, but it still does it. Checked bolts tightened up properly to the correct torque. My local mechanic has suggested putting in some small brass washers under the bolt heads to stop the oil leaking through the bolt thread, but this still hasn't helped.
So hopefully someone here has had these problems and can recommend some solutions. Looking forward to reading them!
