I am currently trying to get an audio configuration for my 2002 Corsa C together but am struggling to get all of the information I require.
I will list what I have decided to use for my new configuration up to now and was wondering if I could have your opinions on this setup.
Component Front Speakers
Product: Rockford Fosgate FNX-2614
RMS: 70 Watt
Peak: 140 Watt
Mounting Depth: 2.8125 (I think this is the depth, if so will this fit?)
Impedence: 4ohms
Frequency Response: 35-20K Hz
Component Tweeters
Product: Rockford Fosgate FNX-2614 Tweeters
Mounting Depth: .625"
Crossovers
Product: Rockford Fosgate FNX-2614 Crossovers
Headunit
Product: Pioneer FH-7000BT
AMP: 4 x 50W
Pre-outs: 2 RCA
I have yet to decide what AMP is best to use for this system and what wattage the AMP should be, any advice would be greatly appreciated.
I will need adapters to put in the 17cm speakers in the front of the car, I hear that MDF ones are the best but harder to get, I have also read about sound deadening but am unsure whether or not to do this.
I also want a subwoofer, from what I have read the best setup for a Corsa C is to have front mid's, tweeters and sub. Can I still connect the standard rear speakers with the headunit I have chosen?
Also will I need two AMP's? One for the speakers and one for the subwoofer.
Thanks,
Craig.
RMS: 70 Watt
Peak: 140 Watt
Impedence: 4ohms
Component Tweeters
Crossovers
Headunit
AMP: 4 x 50W
Pre-outs: 2 RCA
Thanks,
Craig.
