Status
Not open for further replies.
Hi I am currently starting to convert a corsa C van from a 1.3 cdti engine to a c20xe as the old engine has blown and my thoughts were that it would be a better option and more fun
I have the engine, ecu , loom etc but not sure which gearbox to use can I get away with a F17 box as fitted to the van as standard or should I use the F23 box and if so will it bolt directly to the engine ?
Has anyone carried out this conversiion before , any guidance would be most welcome
many thanks
Nick
yes the f17 will be fine as long as you dont do doing burnouts all the time, and the fuel lines will need changing to petrol lines apart from that i think it will be straight forwards to do the swap theres plenty of guides out there and im sure the wires are colour to colour at the ecu same as the corsa b
Wrong section.
Status
