1 - 1 of 1 Posts
Hey all,
My son has a 1.2 2012 Corsa.
He appears to be losing coolant. It’s been fine for a week and this morning he’s told be the bottle is empty.
Originally had a issue with the temperature which was found to be the thermostat as the hot water test nothing happened. So, this was changed, and system bled. Now temperature has been solved.
Now (I think this was happening before the stat issue) it appears the car is losing coolant and needs constant topped up.
It appears to be fine for a week then bang bottle empty (relying on him, big mistake anyway) it looks as if the coolant disappears overnight.
Also the car sounds lumpy and bit chuggy on cold start, not sure if this is related.
1 - 1 of 1 Posts
