1 - 8 of 8 Posts
My drivers side dip is not working its not the bulb and the fuse is ok but when i turn lights on there is a clicking noise in the fuse box what would be the problem
The clicking noise would be probably a relay, or it could be the beam adjustment motor in the headlight but you say its from the fusebox.
Have you tried taking all the plugs out of the head light (4 plugs) and try turning it on and seeing if it still makes that noise?
No i will try it tomorrow now to i see do you think its a faulty relay yes
I unplugged the plug from headlight and the clicking noise still there so i took out fuse 36 and 37 and relay 18 and 21 and clicking noise still there is the relay 18 and 21 for the lights
1 - 8 of 8 Posts
