hi, any help please?
originially had an idle problem, in that it kept fluctutating between 700 - 3000rpm. put it in the garage, they cleaned the throttle body and problem cured.
howvere went to drive it home, and now it wont accelerate over 50mph. when ever i change gear, slow down, and then speed up, pull away, it just wont go, it feels like it wants to but it wont. it judders, and then clears starts to go but then just wont!
were awaiting an airflow meter at the garage, no response yet :(
please help, really cant afford to keep throwing money at my lovely car in the garage~! HELP!
Not sure what you mean by 'Were awaiting airflow meter at the garage, no response yet'. If the AFM is busted then that would account for your problems. Easy way to check - just disconnect the AFM and try it. It won't run perfectly, but it ought to default to a basic factory setting that will enable the engine to at least run.
If disconnecting the AFM makes the engine more driveable then it's most likely a new AFM needed. If not then we'll need to think further.
