Corsa, 2002, Indicator, right front, not working
could be the relay in the fuse box, try replacing fuse first, i'm unsure on your model which one it is, think it's fuse F3 7.5amp on an 05 plate sxi but no idea on your car, sorry..,also try putting the hazzards on and see what happens, then you should hear the relay clicking when you open the fuse box, give it a clean. try a fuse first then i'd go to a scrappy for a relay, good luck
