Hi guys, recently bought a 1999 1.0 12v as a non-runner, the car is in really good nick for it's age and has very low miles. The dealer we bought it off said it was running perfectly until they steam cleaned the engine bay in preparation to sell it, since then it has refused to start. I put a new battery on it and it turned over great however there was no spark at plugs or fuel at the fuel rail, I changed the crank shaft sensor thinking it may be that but still nothing. I've checked for 12 volts at fuel pump; coil pack & ecu plugs - nothing!! Thought it might be immobiliser issue but by what I gather off this forum the eml light usually flashes when cranking engine if it is immobiliser related????. I found a purple relay by the glovebox which I presume is for the fuel pump, this has power on both red cables regardless of the ignition being on or off, tried linking cables with relay removed, fuel pump didn't run but sounded like something clicking at throttle body. Any ideas gratefully accepted otherwise I may attack it with a gallon of petrol and a match!!!!
