Hi all,
Last night in the cold weather I went to use the washer pump and it worked for about 2 seconds then no more water was coming out. But the motor was still making a noise (although a slightly quieter noise than normal), so I just presumed I was out of fluid.
Checked it this morning, and there was plenty in there, so I tried again.
No noise at all... its kaputt. (Wipers still work)
Now, I can't imagine it being the fuse, as it would either work fine, or not work at all... not half and half (make a noise and not squirt). But I will check the fuse, does anyone know which fuse it is? because theres a lot of windscreen images on the back of the fusebox flap.
If thats fine, it's either the washer pump or the stalk... I reckon it's the pump, because of how the noise faded in power yesterday, sound about right?
Or am I missing anything?
