Greeting everyone.
I have a 13ne corsa b from South Africa.
EML started flashing causing no spark or fuel priming so i decoded my ecu. Still nothing after decided to buy another ECU. I bought a 1.4ne dupec ECU and decoded it.
Now i have spark and fuel in the rail but i have no pulse at the injectors. New crankshaft sensor. EML still flashing.
When testing power on the injectors i get 10volts when i turn ignition on fuel relay clicks in but when the relay clicks again and fuel pump stops my voltage drops again to basically nothing.
When swinging the motor the voltage does not pulse but stays steady.
I need help. I've spent a lot of money already on the engine.
How to get pulse on my injectors.
