Hi there, well i think i would change the easy stuff first, afraid its a bit hit and miss, i wouldn't pay too much attention to HT resistance readings, probably not significant as long as there somewhere near, the primary resistance should be about 1 ohm or a bit less......
It sounds like it has a Wasted spark system on, that is a coil with 4 outlets where the lead push in, so no distributor. that being the case it should have a crank sensor on and possibly a cam sensor...still might be worth perusing a code test, i think the socket is on the right side of the steering column on that, in the fuse box??, i did have one years ago, that was a diesel with the Japanese Isusu engine in, i had that for 7 years, it never had a running fault and it never failed to start...mind you the one i have now Corsa C 1-0 litre year 2000 same...never had any problem so far with that...think had that about 6 years..that's petrol...
You done the right things testing the leads with an ohm meter they should have some resistance as there suppressed for radio interference...if they had a break in that would have told you....worst case sanario it could have an ECU fault...but you might want to look on U tube at the code test routine...
By the way what sort of fuel sytem does it have on, Carburetor, single point injection or multi point injection??
from Fred in Essex.
Just had a quick look and it has an ignition coil pack. I checked the secondary windings with a multimeter and one reads 5.48kohms and the other 5.45kohms. I tried squirting water around any vacuum hoses with water from a washing up liquid bottle and did not notice any drops in rpm or rough idling.
Checked plug leads with meter and seem to be ok, had a good look at filter and does need a new one, so guess next step is replace filter and plugs? Cheers
