Hi
I have a 1997 corsa b 1.4 and when u full up with fuel, the pump just clicks off straight away, at first I thought it was the pump, but I've tried several now at different garages, and there all the same, so it's a nightmare to fill it up, I'm guessing there's some kind of restriction in the pipe, not allowing the fuel to run into the tank quick enough, causing the pump to click off...
I was just wondering if anyone had any suggestions, or if this was common, and if there's a fix??
Thanks in advance
Steve
Thanks for the replys, I'll have a look with a torch and see if there's anything restricting it, if not al check the breather, by the way, where abouts is it?? And is it just a case of blowing it out with an airline??
But surely if the breather was blocked there'd be other issues too?
