1 - 1 of 1 Posts
Hi everyone, am after some advice if any one could help, I've took engine out my corsa which is a 1.0 12v, wanted to put a old nova 1.2st 8v engine in, to realise it be too much effort and hard work with the wiring ecu etc unless someone has a solution 🙈,
Car Vehicle Blue Motor vehicle Light
with the current wiring ecu is there any other engine that will go straight in using the current wiring and ecu 🤔 or has it got to be the 1.0 12v as its running 3 cylinders and ecu registered to that 🤷‍♂️ any help would be appreciated cheers
Blue Black Motor vehicle Vehicle Gas
1 - 1 of 1 Posts
