1 - 8 of 8 Posts
Ive just dropped a c20ne in my corsa and im wanting to know how to wire it to the new loom, thr eps light is on on instrutment panel, but it doesnt go off and work, im just wanting to know if anyone has wired it up before, and if they have a wiring diagram to sort it.
Get a multi meter, and there should be a green wire going to your EPAS ecu, one side on the multi meter and the other where it is on the coilpack, see if there is a link (connection between the rev meter wires and the Epas) Also have you made sure the wires are getting power to the epas ecu etc. Check all cables to make sure the ecu is getting power and the ground is in etc. That's what I can think of.
1 - 8 of 8 Posts
