Hey guys,
This is my second post up about my corsa B 1.0 flat spotting/hesitation
This problem only creeps up when the engine temp gets just above 90, and when you try take off normally its almost like a stalling sensation with the engine running, and im sure i can also hear a back firing while its rolling forward as well?
This also sometimes happens while driving normally youll feel the cars power dip randomly, then pick up again?
Its getting to a point where its getting quite dangerous now too! you dont want that happening across a round about or busy traffic flow
how ever on a cool night if i went for a drive it feels as tight as a drum, as good as the day i bought it? So there fore its a temperature sensitive part..
So either...
Ive gotta drive every where like my hairs on fire:thumbs_up:
Drive ever where at night Or...
Sell it to some one in poland?
I've replaced a multitude of parts in my car, and this stupid problem isnt going away
1. Full service (oils, plugs, filters)
2. MAF
3. Engine coolant sensor
4. Camshaft sensor
5. Cleaned throttle body housing
6. Coil pack
7. EGR valvue
8. Fuel filter
9. Taken rocker cover off and checked timing (Perfect!)
And after all that theres still the problem...
Its been suggested that maybe its the fuel pump packing up or being blocked, but as is the way its not as simple as being attached to the cover you remove under the back seats, it looks like its on the bottom of the fuel tank??
Any ideas guyss??
Any help much appreciated!
Thanks in advance!
Stew
So either...
2. MAF
4. Camshaft sensor
6. Coil pack
7. EGR valvue
8. Fuel filter
Any ideas guyss??
Thanks in advance!
Stew
