1 - 7 of 7 Posts
Hi guys, i decided to make another thread due to the fact that the other one is cluttered with questions, as stated in the other one, i done a compression test on my car, doing a dry then wet test on each cylinder however the compression tester was crap and didn't work properly, after about 10-15 minutes of running fine, the car started misfiring badly. I decided to take the plug out to clean them and they where all black. Now these plugs are probably more than 3 years old. This is there condition after a clean.
It's 'bit' out of focus, but you can see that the earth electrodes are worn.
Also that plug looks a bit sooty, but if the engine had not been running for very long before you took the plugs out, it may just be down to the richer starting mixture.
I would treat it to a new set of plugs whilst they are out and if it is anything like due for a FULL service, give it a birthday while you are at it.
If there are still problems after that, it would be a good idea to get any fault codes read, rather than guessing at possible causes and buying parts that you may not even need.
Regards.
Thanks for that mate, i think the plugs are actually older than 3 years old to be honest. Might as well just replace them as they're cheap. Also i done a spark test and one doesn't spark, one seems fine and the other one has a weak spark as its orange/yellow. Think this may be the problem.
Ok guys well I went to see if anywhere was opened to get spark plugs but there wasn't so my mate let me try the plugs out of his corsa which has a x12xe however these didn't work either, I tried mine in his also and they worked fine. Is there anyway the coil pack could be toast and is there anyway to check it before I shell out on a diagnostics reader?
Apart from visually checking the coilpack - look for signs of cracks or deposits around where the contacts with the plugs are - the only real way is to swap for a known good one. Aftermarket ones tend to be less reliable, so I'd stick with the genuine article if you can.
If you used your coil pack for the HT when you did the spark test, the fact that one didn't work and one gave an orange/yellow spark, MIGHT just be telling you all that you need to know.
As said above though, some of these 'will-fit' coil packs, as well as some other components, can leave a lot to be desired - I know that people will say that they have used them and not had trouble - Aren't they lucky!!
Regards.
1 - 7 of 7 Posts
