Hi
I think my fuel tank breather is blocked as it wont fill up with petrol properly so a was wanting to clean it out n stuff and I was wondering where it was located?
My car is a corsa b 1997 1.4 8v
Thanks in advance
Steve
If you get underneath the car you will see the main pipe from the filler cap down to the tank, runnin directly along side this you will see a pipe around 10 cm in diameter also going to the tank from the filler, said item :)
