Hi
i have recently bought a Corsa B and would like some help with the parcel shelf. It does not connect to the boot, so when you open the boot the shelf stays stationary. The straps are connected to the shelf but there doesn't seem to be anywhere on the boot where they can strap into. There are 2 holes but there appears to be some connectors missing, would i be able to buy these anywhere and if so do you know where. Would i need to know part numbers or what they are actually called? all help would be appreciated
best thing to do is probably go to a scrappies and get them then you know that they are defo what you need!!!
Cheers
Billy
Reactions: daniboi09
The party you need are help on by torx bolts, alot of people just brake these off to get to the lining behind(as apoart form them torx bits they are held on by plastic clips. Have a look at scrappies or describe at a vauxhall near you:)
