1 - 1 of 1 Posts
Hi Guys..
Daughters corsa c 02 1.0 has a intermittant starting problem. It starts then runs for a second or two and then stops. On trying restart it starts again but then runs again for less time and so on. Leave it 15 minutes or so and it will then start and run fine....Doesnt do this very often every couple of weeks or so..
Any Clues ??
Thanks again in advance.
PS appear to have cured the leaky gasket behind timing cover with Engine leak sealant HD version ( touch wood! ) had to drain the cooling system twice to do it but seems to have done the trick.
1 - 1 of 1 Posts
