1 - 7 of 7 Posts
Hi, we have a corsa c 2003 I think it's z10xe engine code. The engine seems to misfire when idling and makes the whole car vibrate - does not run smooth! It drives ok. I connected it to the computer and got the following errors: 2 errors P0141 which is O2 sensor heater circuit bank 1 sensors 2; P0303 cylinder 3 misfire detected; P1300 ignition coil 1 primary circuit.
I reset the errors and just get 2 P0141 at the moment so need to sort out that first I think. There is that sensor is it the top of the engine one at the front?
Any help is much appreciated
Remember that the O2 sensor is a feedback system, so anything that causes a misfire will cause the exhaust gases to be out of parameter. The O2 code just shows the symptom, it's probably not the cause.
Crankshaft sensors usually either show as a non-starter, or they will start and run fine until they get hot (say 10-15 minutes) and then cut out and refuse to start until it's cooled down.
Your problem could be any number of issues, bad plug, injector, dirty filters, sticking EGR valve (occasionally shows as a misfire on the nearest cylinder)....and the 3-pot engine is always rough on idle, it's the nature of them. That can lead to a cracked exhaust manifold which will also throw an O2 code. That in turn feeds back to the ECU which thinks the fuel mix is out so the ECU alters the fuel mix and you get a misfire.
So they are all things you may need to check.
If you can borrow a known good coilpack it's worth trying a swap to see if that makes any difference.
We have tried another coil pack and changed spark plugs. Yesterday tried another egr valve, but still the same problem. It idles pretty bad that you can see the whole car moving/shacking. When accelerating it makes a weird roar noise like it has a loud induction kit.
Did you find out the problem with the ruff idling
it is the co2 sensor at top of manifold ,that is the heat co2 sensor the top one ,the other one is located on the doewpipie underneath the car before it enters the center box,in this case it is top sensor then codes cleared and no blows in the exhaust system ,there is also 2 breather hoses on top of engine that gives way, they just bust and let air in clogs the top co2 sensor,
1 - 7 of 7 Posts
