1 - 7 of 7 Posts
:) All / Anyone
I hope someone can assist.
I have just bought a digital temperature gauge, so my question is can it be sliced in too the existing two wire CTS loom so I can still use my existing water temp gauge and this digital one?
The digital gauge has three wires: one earth, one live and one for the sender.
Hope this makes sense and many thanks in advance :D
I have had a look at the wires on the car's loom, I have one green which I would suspect is signal wire and one grey but just unsure if my green wire on new digital gauge can just be added to that existing loom wire too which I can then use original and digital gauges together?
I'm not sure if u could, but there's no harm in tryin... And I don't see why u couldn't Jus cut into ur existing loom, and join that one in, and see if it works, if it does result :) if not then jus take your digital one out
Will have too fook about buying a separate adapter then cut open coolant hose if it doesn't work.
As the digital one is more accurate compared to standard, down side is standard one is connected to ecu and CTS makes sure car fuels right, that's why I'm not one for just cutting wires at random. :laugh:
1 - 7 of 7 Posts
