Hi,
Hoping someone can help!
Only since recently, when I start my engine up, I'm hearing a noise coming from the fuel pump under my back seats. It's an intermittent sound, kind of like a scratching noise. I'm not sure if it's the filter or the pump that needs to be replaced/fixed, is there a way I can know for sure? Doesn't make the noise as much while driving, but is still there.
Thanks in advance!
Alan.
I would say it's a noisy fuel pump by the sound of it,wouldn't be the filter as if faulty wouldn't make a noise,just restrict the fuel supply.I would remove and check the pump for anything obvious,and if there is nothing that you can see loose or blocking it,renew it as sooner rather than later it may stop working all together and let you down.
