1 - 1 of 1 Posts
i do have a video of my fault also... its had 2 new relays this year... one time when I fitted a new relay it stayed the same , left it and eventually it fixed itself which is weird , I get a issue with Auto Search on diagnostics tool now as well as it doesn't pull the vin like it use to , to identify the car , sometimes i get the car with the spanner flashing and doesn't start it just cranks over till i cycle the ignition fully and it starts up , is this a BCM fault? I did get water in the BCM box before this happened as the common seal went on it ? is this a corrosion issue on the BCM ? has anyone else had this? many thanks Tyler , i have a video here ( 1
( 2
( 3
) any more info please ask
Rectangle Font Parallel Screenshot Number
Product Font Rectangle Screenshot Parallel
1 - 1 of 1 Posts
