Hi can someone please help. My 52 plate 1.0L corsa has no power when trying to accelerate and judders as if it's getting power then loosing it again. It was working fine until I put petrol in from a different place to usual. The engine management light came on briefly 6 or 7 hours after the problem started and problem is getting worse as time goes by. We plugged it into computer and came up injection circuit open. Then tried again several times with no codes coming up.
Please help x
I think that you have more or less answered your own question here.
It sounds very much as if you have bought some duff petrol - maybe even 'bought some water'!
It might pay to change the petrol filter, but after that, you are left with the choice of either cleaning out the tank and starting with fresh petrol OR putting up with it 'till the duff stuff has passed through - if you do the latter, you MAY have to change the filter more than once, depending upon how much and what sort of muck you have got in there.
Regards
